Normal Topic IgnoreLayout question (Read 3209 times)
jcaron
Sep 25th, 2019 at 1:39pm
I have a diagram that is originally generated automatically. I allow the user to move nodes and would want to keep the positions of those nodes when I reapply the automatic layout (I use the Fractal layout). I tried using the Ignorelayout property that I assigned to true during the NodeModified event. Unfortunately, the positions are not maintained when I reapply the automatic layout. Am I missing something?
Thanks!
Jean
Re: IgnoreLayout question
Reply #1 - Sep 26th, 2019 at 3:48am
I've tried this modification of FractalLayout example and the printed position is the fixed one -
RandomTree(root, 5, 4);
Arrange(root);
if (ignored != null)
    Debug.WriteLine(ignored.Bounds);
DiagramNode ignored = null;
void RandomTree(DiagramNode node, int depth, int minChildren)
        if (diagram.Nodes.Count == 10)
            child.Move(42, 42);
            child.IgnoreLayout = true;
            ignored = child;
I guess apparent position on screen could change if you use some form of auto-resizing and Diagram.Bounds' origin changes. In that case you could record relative positions of ignored nodes in a Dictionary<DiagramNode, PointF> and reapply the offset back after the origin changes. Or if DiagramNode.Bounds is really not preserved for you, then you could store and restore positions via a Dictionary<DiagramNode, RectangleF> map.
jcaron
Reply #2 - Sep 26th, 2019 at 8:06pm
Good day Slavcho,
Thanks for the quick answer, I readjusted a few things in my code and got it to work.
I have yet to try with the other layouts, but the Fractal version does not seem to take the position of the fixes diagram items into consideration - it almost seem as if it ignores those nodes from its calculation of the positions of connected nodes.
Would you know if the other layout algorithm would behave the same?
Or options to make the layout calculations to consider the fixed nodes as a constraint in their evaluation?
Thanks and regards,
Jean
Reply #3 - Sep 27th, 2019 at 6:45am
That's what IgnoreLayout does, the layout code doesn't know ignored nodes exist at all. This option is to keep decorative / background or group subordinate items at their original locations (relative to the group for latter ones). If you need fixed nodes that exert influence on other ones but don't move themselves, try SpringLayout with the SpringLayoutTraits.Frozen option.
jcaron
Reply #4 - Oct 2nd, 2019 at 8:33pm
Thanks Slavcho for your explanations. I am experimenting with the Springlayout and the Frozen trait, it is slower than the Fractal, but results are much better visually - at least for the diagram I use for testing.
Thanks for the good support!
Jean
