Normal Topic CompleteModify method isn't called while moving multiple nodes (Read 3374 times)
Ashot
Oct 26th, 2020 at 2:32pm
If I select one node and move it, the node will fire StartModify and CompleteModify methods. If I select multiple nodes and move all of them, all nodes will fire StartModify, but not CompleteModify. Could you please explain this behavior? Is it expected behavior or just a bug?
please have a look at the attached demo sample. Just run, move nodes and look in the output window.
CompleteModifyDemo.zip (Attachment deleted)
Online
Re: CompleteModify method isn't called while moving multiple nodes
Reply #1 - Oct 26th, 2020 at 3:02pm
It calls a different CompleteModify(bool, InteractionState) overload when moved with multiple selection, but that one is internal. We'll have in mind publishing it or unifying the overloads for upcoming release. As a work-around you could handle the SelectionModified event to update nodes for time being.
Ashot
Reply #2 - Oct 26th, 2020 at 3:33pm
thank you for your quick response.
Is it going to be fixed soon or it worths making workarounds?
Online
Reply #3 - Oct 27th, 2020 at 5:40am
We should release in a couple of weeks.
Ashot
Reply #4 - Oct 27th, 2020 at 8:14am
Thank you.
Online
Reply #5 - Oct 28th, 2020 at 9:51am
We won't be able to unify them for current release. This build adds protected visibility to the other overload -
https://mindfusion.eu/_temp/wpfdiag_clr45_complete.zip
So the one you already override in your project is called for direct modifications of specific DiagramItem, the newly visible one is called for indirect ones (through groups, container children, node's links, multiple selection...)
