Normal Topic Diagramming for WPF, V3.6.1 (Read 1918 times)
Nov 3rd, 2020 at 1:20pm
We have released version 3.6.1 of WPF Diagram control. It contains the following new features and improvements:
.NET Core assemblies
The distribution now includes assemblies for .NET Core 3.1. Automatic VS toolbox integration is not available at this time; you must add diagramming.wpf assembly references to the project manually or through Nuget, and then add corresponding elements to Xaml markup for the various controls from the library.
  • The MoveNodes behavior allows grabbing nodes to drag them without using adjustment handles.
  • Added protected visibility to CompleteModify overloaded method of DiagramItem, called for indirect modifications.
  • PanBehavior class used to implement Pan and PanAndModify behaviors is now public, allowing deriving custom behaviors from it.
  • ArrangeAnimated fixes.
API changes
NodeModifying and LinkModifying events are now also raised for items in multiple-selection.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
« Last Edit: Nov 30th, 2020 at 1:06pm by Forum Admin »
