Very Hot Topic (More than 25 Replies) Routed links different in silverlight and html5 (Read 10023 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
May 19th, 2021 at 3:16pm
I've attached the same diagram in silverlight and html5 but the link between Node # 1 and Node # 3 is different. May I know how to achieve the same silverlight linking in html5?
Kannan
Re: Routed links different in silverlight and html5
Reply #1 - May 20th, 2021 at 5:20am
Try diagram.setLinkRouter(new GridRouter()). The RoutingOptions values from Silverlight are properties of GridRouter in JavaScript version.
Kannan Thirumal
Senior Member
Reply #2 - May 20th, 2021 at 6:01am
I tried this but getting this error. May I know how to resolve this?
TypeError: Cannot read property 'routeMargin' of undefined
    at bv7.GridRouter.boW.Router (https://localhost:44395/vendor.js:321027:29)
    at Object.initializeBase (https://localhost:44395/vendor.js:144627:23)
    at new bv7.GridRouter (https://localhost:44395/vendor.js:321998:26)
Kannan
Reply #3 - May 20th, 2021 at 8:12am
The constructor expects Diagram argument -  GridRouter(diagram)
Kannan Thirumal
Senior Member
Reply #4 - May 20th, 2021 at 3:39pm
It seems working fine. Thank you Smiley
Kannan Thirumal
Senior Member
Reply #5 - Jun 14th, 2021 at 8:39am
After this change, when I drag and drop the element near the right side border, then getting the below exception. May I know why is this happening and how to fix it?
core.js:4002 ERROR TypeError: Cannot set property '62' of undefined
at eK.<computed>.set (MindFusion.Common.js:6)
at bup.<computed>.markObstacles (MindFusion.Diagramming.js:6)
at bup.<computed>.routeLinks (MindFusion.Diagramming.js:6)
at acO.<computed>.routeLinksAt (MindFusion.Diagramming.js:6)
at a6a.<computed>.endDrag (MindFusion.Diagramming.js:6)
at a1i.<computed>.commit (MindFusion.Diagramming.js:6)
at a2k.MouseInputDispatcher.onMouseUp (MindFusion.Diagramming.js:6)
at a1X.<computed>.onMouseUp (MindFusion.Diagramming.js:6)
at HTMLCanvasElement.cQ (MindFusion.Common.js:6)
at ZoneDelegate.push../node_modules/zone.js/dist/zone.js.ZoneDelegate.invokeTask (zone.js:421)
I've attached the screen shot. I've dragged and dropped the element Decision-H2.
I've uploaded the sample here: https://drive.google.com/file/d/1j4hSvwRBjePdsVBmryWqRPNkToLaIwA-/view?usp=shari
ng
Regrads,
Kannan
Reply #6 - Jun 15th, 2021 at 1:38pm
This build should fix it -
https://mindfusion.eu/_temp/jsdiag_gridrouter.zip
Kannan Thirumal
Senior Member
Reply #7 - Jun 15th, 2021 at 7:27pm
This seems working fine. May I know when this will be released?
Kannan
Reply #8 - Jun 16th, 2021 at 4:44am
We won't be releasing new 3.* versions anymore. Use the js files above, or we could publish them as a patch on the NPM registry if you prefer using the diagram-library package from there.
Kannan Thirumal
Senior Member
Reply #9 - Jun 16th, 2021 at 7:55am
We used to update our code using "npm install". If you publish this as a patch, will this work by doing "npm install"?
Kannan
Reply #10 - Jun 17th, 2021 at 5:46am
We've published that build as v3.5.5 on npm -
https://www.npmjs.com/package/diagram-library
Kannan Thirumal
Senior Member
Reply #11 - Jun 17th, 2021 at 4:29pm
I'm getting this error when moving the element over other element's link,
TypeError: Cannot read property 'length' of null
    at bz2.<computed>.segmentsFromPoints (https://localhost:44395/vendor.js:363536:38)
    at bz2.<computed>.pullLinksApart (https://localhost:44395/vendor.js:363562:44)
    at bz2.<computed>.routeLinks (https://localhost:44395/vendor.js:363417:24)
    at adH.<computed>.routeLinksAt (https://localhost:44395/vendor.js:345229:39)
    at a71.<computed>.endDrag (https://localhost:44395/vendor.js:336873:57)
    at a29.<computed>.commit (https://localhost:44395/vendor.js:339685:24)
    at a3b.<computed>.onMouseUp (https://localhost:44395/vendor.js:339915:50)
    at a2O.<computed>.onMouseUp (https://localhost:44395/vendor.js:339815:38)
    at HTMLCanvasElement.cQ (https://localhost:44395/vendor.js:189077:28)
    at ZoneDelegate.invokeTask (https://localhost:44395/polyfills.js:1233:173)
Kannan
Lyubo
MindFusion team
Reply #12 - Jun 18th, 2021 at 8:36am
Try with the new published 3.5.6 version on npm -
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #13 - Jul 1st, 2021 at 12:38pm
The link between the Node # 1 and Node # 2 is not straight. Please check the attached screen shot. But, it is straight in silverlight (ie it passes through the label. please check previous post attachment)
Kannan
Slavcho wrote on May 20th, 2021 at 5:20am:
Reply #14 - Jul 1st, 2021 at 1:09pm
If you use attached nodes to show labels, set the labels' Obstacle property to false.
