Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) Issue with text on SVG node. (Read 10866 times)
Re: Issue with text on SVG node.
Reply #30 - Dec 2nd, 2022 at 9:19am
FontWeight support was added to SvgExporter, converting the values to CSS numerical weights. SvgNode recognizes only symbolic 'bold' weight at this time.
nullable
Reply #31 - Dec 9th, 2022 at 11:18am
Hello, I wanted to check if there is progress in the implementation of "import-as-text" option, because this feature is essential for me.
nullable
Reply #32 - Dec 16th, 2022 at 6:09am
Hello. I still need "import-as-text" feature. Want to know if you've implemented that.
Reply #33 - Dec 19th, 2022 at 3:16pm
It should be available for upcoming v3.9 release.
nullable
Reply #34 - Dec 20th, 2022 at 8:24am
Can you please say ETA of version 3.9 release?
nullable
Reply #35 - Dec 22nd, 2022 at 10:59am
Also, what about font weights support for SVG importer?
nullable
Reply #36 - Dec 26th, 2022 at 5:33am
I want to notice that I'm still waiting for your reply.
Reply #37 - Dec 26th, 2022 at 10:04am
It's done when it's done says our developer; SVG text is not that simple with possible embedded spans etc. Generally we are not marketing this library as an SVG editor and do not owe you any of this. SvgNode was added only to let our users show vector-icons in their flow diagrams.
Reply #38 - Dec 27th, 2022 at 11:53am
Try new build here -
https://mindfusion.eu/_beta/wpfdiag39.zip
Text rendering is behind a flag for time being, disable static SvgText.DrawAsPath to test it -
SvgText.DrawAsPath = false;
var defaultBounds = diagram.Bounds;
var text = new TextNode();
text.Bounds = new Rect(55, 55, 50, 20);
text.Text = "test";
diagram.Nodes.Add(text);
var text2 = new TextNode();
text2.Bounds = new Rect(85, 80, 120, 45);
text2.Text = "test1 test2\r\ntest3";
diagram.Nodes.Add(text2);
diagram.ResizeToFitItems(22);
new SvgExporter().Export(diagram, "test_t.svg");
diagram.ClearAll();
diagram.Bounds = defaultBounds;
var svg2 = new SvgContent();
svg2.Parse("test_t.svg");
var svgNode2 = diagram.Factory.CreateSvgNode(
    330, 0, 100, 200, svg2);
svgNode2.Shape = Shapes.Rectangle;
svgNode2.Transparent = true;
var svg3 = new SvgContent();
svg3.Parse("test_t.svg");
var svgNode3 = diagram.Factory.CreateSvgNode(
    110, 0, 100, 200, svg3);
svgNode3.ContentAutoBounds = true;
svgNode3.Shape = Shapes.Rectangle;
svgNode3.Transparent = true;
new SvgExporter().Export(diagram, "test3.svg");
We'll try to add font weight parsing in next few days.
nullable
Reply #39 - Dec 27th, 2022 at 12:54pm
Hello! Now SVG import/export with text works just perfectly, thank you! Smiley
Reply #40 - Dec 28th, 2022 at 1:19pm
This build parses font-weight values -
nullable
Reply #41 - Dec 28th, 2022 at 1:26pm
This feature is working perfectly as well. Thank you so much for the updates. Roll Eyes
