Normal Topic Issue with bitmap cropping when exporting via SvgExporter (Read 1109 times)
Dducky
Dec 29th, 2022 at 5:13am
The issue related with bitmap cropping when exporting via SvgExporter.
The code:
// Set the position to the origin.
            // Its just an example node that draw a bitmap.
            // This node doesn't have 'RenderTransform' or 'RotationAngle'.
            // It will render correctly.
            var testImageNodeBounds = Bounds with { X = 0, Y = 0 };
            var testImageNode = new SvgNode()
                Image = bitmapImage,
                Transparent = true,
                Bounds = testImageNodeBounds,
                TextBrush = Brushes.LightBlue,
            testImageNode.Text = $"Bounds: {testImageNodeBounds} \n " +
                $"Rotation is: {testImageNode.RotationAngle} \n " +
                $"Render transform is: \n {testImageNode.RenderTransform}";
            // This is the real one.
            // We are trying to draw an image that have a 'RotationAngle' and 'RenderTransform'.
            // It will be cropped.
            var realImageNode = new SvgNode()
                Transparent = true,
                RenderTransform = RenderTransform,
                RotationAngle = RotationAngle,
                Bounds = Bounds,
                Text = $"Bounds: {Bounds} \n Rotation is: {RotationAngle} \n Render transform is: \n {RenderTransform}",
            printDiagram.Items.Add(testImageNode);
            printDiagram.Items.Add(realImageNode);
I also tried to export into stream/file but anyways its cropped:
var svgExporter = new SvgExporter()
            SetClipPaths = true,
        var svgStream = new MemoryStream();
        svgExporter.Export(atsDiagramControl, svgStream);
        svgStream.Seek(0, SeekOrigin.Begin);
        svgExporter.Export(atsDiagramControl, "testSvg.svg");
1) See the diagram that we expect while exporting.
2) The resulting SVG after export (by SvgExporter). For some reason cannot upload the resulting SVG, I am attaching the file that I posted on the file hosting: https://dropmefiles.com/sQFCB
Re: Issue with bitmap cropping when exporting via SvgExporter
Reply #1 - Jan 2nd, 2023 at 5:56am
This is not showing cropped bitmaps in our test, please post your exact values:
var bitmapImage = Utilities.LoadImage("59547975.jpg");
var node1 = new SvgNode()
	Transparent = true,
	RotationAngle = -130,
	Bounds = new Rect(50, 50, 250, 200),
var node2 = new SvgNode()
	Transparent = true,
	//RenderTransform = new TranslateTransform(-50, 20),
	//RenderTransform = new ScaleTransform(2, 2),
	RotationAngle = 30,
	Bounds = new Rect(330, 50, 200, 250),
diagram.Items.Add(node1);
diagram.Items.Add(node2);
svgExporter.Export(diagram, "testSvg.svg");
Also RenderTransform is set internally by the control to match Bounds and RotationAngle, you shouldn't be able to override it unless assigning to it last after those properties.
