Normal Topic Disable link text popup (Read 187 times)
Gagandeep Singh
Mar 1st, 2024 at 7:46pm
Hi there,
I want to disable adding link description when we double click on link. However, I am trying to do like this
Code (Javascript)
 diagram.addEventListener(Events.linkDoubleClicked, (sender, args) => {
        args.cancel = true;
But this doesn't work
Re: Disable link text popup
Reply #1 - Mar 2nd, 2024 at 2:46pm
You can cancel that from Events.linkTextEditing handler.
Gagandeep Singh
Reply #2 - Mar 4th, 2024 at 3:19am
No it doesn't work either. Just don't want that textarea to show when we double click on link
Reply #3 - Mar 4th, 2024 at 8:09am
Make sure you are handling linkTextEditing event, and not linkTextEdited. This does not show text area in my test:
diagram.addEventListener(Events.linkTextEditing, onLinkTextEditing);
function onLinkTextEditing(sender, args)
	console.log("onLinkTextEditing");
	args.cancel = true;
If you are on old version that does not have the event, you can disable allowInplaceEdit altogether and call beginEdit method from nodeDoubleClicked handler.
