Normal Topic SVG / PDF Exporters problem while exporting templated ShapeNodes (Read 1489 times)
MikeB
May 13th, 2024 at 11:01am
When i try to export diagram that contains templated ShapeNodes
there is a problem with rendering a DataBinded properties.
<Window x:Class="Diagraming.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:Diagraming"
        xmlns:diagram="http://mindfusion.eu/diagramming/wpf"
        mc:Ignorable="d"
        Title="MainWindow" Height="450" Width="800">
    <Grid>
        <Grid.RowDefinitions>
            <RowDefinition/>
            <RowDefinition/>
        </Grid.RowDefinitions>
        <Button Content="Export to PDF" Grid.Row="0" Click="ExportToPdf_Click"></Button>
        <diagram:DiagramView x:Name="diagram" Grid.Row="1">
            <diagram:DiagramView.Resources>
                <Style TargetType="{x:Type diagram:ShapeNode}">
                    <Setter Property="Template">
                        <Setter.Value>
                            <DataTemplate>
                                <Label Background="Yellow" Content="{Binding Text, RelativeSource={RelativeSource FindAncestor, AncestorType=Window}}"></Label>
                            </DataTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
            </diagram:DiagramView.Resources>
        </diagram:DiagramView>
    </Grid>
</Window>
Code (C++)
namespace Diagraming
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window, INotifyPropertyChanged
        [field: NonSerialized]
        public event PropertyChangedEventHandler PropertyChanged;
        public void NotifyPropertyChanged(string propertyName)
            if (PropertyChanged != null)
                PropertyChanged(this, new PropertyChangedEventArgs(propertyName));
        public Diagram diag { get; set; }
        private string text;
        public String Text
            get
                return text;
            set
                text = value;
                NotifyPropertyChanged("Text");
        public MainWindow()
            InitializeComponent();
            this.DataContext = this;
            Text = "Test";
            diag = new Diagram();
            diag.Nodes.Add(new ShapeNode()
                Shape = new Shape(new ElementTemplate[]
                            new LineTemplate(0, 0, 100, 0),
                            new LineTemplate(100, 0, 100, 100),
                            new LineTemplate(100, 100, 0, 100),
                        }, FillRule.EvenOdd),
            diag.Nodes.Last().Move(50, 25);
            diagram.Diagram = diag;
        private void ExportToPdf_Click(object sender, RoutedEventArgs e)
            var exporter = new PdfExporter();
            //foreach (var diag in diagrams)
                exporter.Export(diag, @"D:\temp\diagram.pdf");
Re: SVG / PDF Exporters problem while exporting templated ShapeNodes
Reply #1 - May 13th, 2024 at 12:36pm
AncestorType=Window does not work because node presenters created by PdfExporter are not in the window's logical tree. We could add an option to export a DiagramView instead of a Diagram to reuse the view's logical tree, or maybe pass another UI object to set as logical parent. We'll have that in mind for next release.
MikeB
Reply #2 - May 14th, 2024 at 8:07am
Thanks for your reply.
I've found one more strange behaviour when using unicode characters in TextBlock used as DataTemplate. Two examples bellow.
This text causing exception when i try to make pdf export, but on diagram is rendered properly.
                        <Setter.Value>
                            <DataTemplate>
                                <TextBlock Text="&#x16C;&#x117;" Background="Yellow" FontFamily="Arial"/>
                            </DataTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
Another example for different unicode characters shows difference between diagram visualization and exported pdf (extra space character and text offset).
<TextBlock Text="&#x15B;&#x107;" Background="AliceBlue"  FontFamily="Arial"/>
Reply #3 - May 14th, 2024 at 9:26am
Exporter's encoding detection seems to fail in that case. Try this to fix the exception:
exporter.DefaultEncoding = Encoding.Unicode;
exporter.Export(...);
MikeB
Reply #4 - May 14th, 2024 at 9:51am
Thanks. That worked for the first example, but not for the second. Look for the attached screenshoots.
Reply #5 - May 14th, 2024 at 10:13am
Actually you'll also need to disable AutoDetectEncoding for DefaultEncoding to be applied everywhere:
exporter.AutoDetectEncoding = false;
WPF appears to apply font fallback when the ttf file does not contain some glyphs, and unfortunately PdfExporter does not detect that. In this case Arial falls back to Arial Unicode MS. We'll see if we can detect that automatically for next release. At this time this seems to fix the sc string:
<TextBlock Text="&#x15B;&#x107;" Background="Yellow" FontFamily="Arial Unicode MS"/>
MikeB
Reply #6 - May 14th, 2024 at 12:06pm
Thanks, now it works Cool
