Page Index Toggle Pages: 1 2 3 [4] 5 6 7 Send TopicPrint
Very Hot Topic (More than 25 Replies) PocketPlannerDesign for .NET 2.0 (Read 56938 times)
Re: PocketPlannerDesign for .NET 2.0
Reply #45 - Apr 10th, 2006 at 5:49am
yep, handle the DateClick event and check the Clicks argument. If Clicks = 2, then change the CurrentView and set the TimetableSettings.Dates so it displays the date clicked in the weekrange view.
I will check with our developers about the scrollbar and let you know later.
racer
Guest
Reply #46 - Apr 10th, 2006 at 6:55am
must you set that click event in the
Private Sub _menuWeekRange_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles _menuWeekRange.Click
   _calendar.CurrentView = CalendarView.WeekRange
         End Sub
or is that an seperate method
Reply #47 - Apr 10th, 2006 at 9:12am
There is a DateClick event that will let you know exactly which date is clicked in the week range.
racer
Guest
Reply #48 - Apr 10th, 2006 at 9:43am
you know i have a demo with 3 calendars but when i want to save and load them he gives nothing back on the timetable
Private Sub _menuSave_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles _menuSave.Click
       _calendar.Schedule.Save("schedule.save")
       Calendar1.Schedule.Save("schedule.save")
      Calendar2.Schedule.Save("schedule.save")
    End Sub
    Private Sub _menuLoad_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles _menuLoad.Click
       _calendar.Schedule.Load("schedule.save")
       _calendar.Invalidate()
        Calendar1.Schedule.Load("schedule.save")
        Calendar1.Invalidate()
        Calendar2.Schedule.Load("schedule.save")
        Calendar2.Invalidate()
    End Sub
i changed like you see but when i save it he gives nothing back
Reply #49 - Apr 10th, 2006 at 10:33am
Do you save all three schedules into the same file ? The last schedule will overwrite the information for first two, it won't just append its items to the file.
racer
Guest
Reply #50 - Apr 10th, 2006 at 11:04am
i have a question can you fill the timetable from an sql mobile 2005 database or is it only in xml file
Reply #51 - Apr 10th, 2006 at 12:28pm
You will have to implement that yourself, i.e. iterate dataset records, read item values, create Appointment objects and assign the values to their properties.
racer
Guest
Reply #52 - Apr 10th, 2006 at 3:29pm
oh so you have never tried it before
i must read it out from a sql mobile database into the timetable and also save the new appointments
haven't you any example of that or some more specifik information because i have never done that before  Embarrassed
Reply #53 - Apr 10th, 2006 at 4:28pm
I'm afraid we haven't used mobile SQL server and don't have any example. Do you have any specific difficulty serializing the appointments into the SQL server ?
racer
Guest
Reply #54 - Apr 11th, 2006 at 4:39am
wel for the loading and saving of the appointments i don't know how to start
maybe i must start with creating an appointment object and assign the values to their properties.
racer
Guest
Reply #55 - Apr 11th, 2006 at 5:33am
i have a question about saving the appointments
in the demo stands
but i have seen that when i save today an appointment i didn't see it in that schedule.save
the last save was from the 4 of april
were are the appointments then saved
Reply #56 - Apr 11th, 2006 at 6:20am
Regarding scrollbars in WeekRangeView - they are displayed only when needed, i.e. not all contained days are visible at a time. To show a vertical scrollbar, you either select wider range of dates by using Calendar.Date and Calendar.EndDate, or you choose less days to be visible at a time, by reducing the number of visible rows in the view (Calendar.WeekRange.VisibleRows).
As for saving and loading appointments you can either save the entire schedule to a string by calling Schedule.SaveToString, then writing this string to the SQL database, or save appointments individually, which would require some efforts.
racer
Guest
Reply #57 - Apr 11th, 2006 at 7:00am
i have tested the demo.exe and when i saved there appointments i see that the schedule.save increase
but when i save an appointment from the demo that you gave me with the 3 kalenders he saved it because i can load them after but the schedule.save doesn't increase
is there an extra method in the demo.exe to save that in schedule.save (because in the demo with the 3 kalenders there is just one coderule and thats it ???
Reply #58 - Apr 11th, 2006 at 10:05am
I am not sure I understand that last post - do you need to save all three schedules in the same file ?
racer
Guest
Reply #59 - Apr 11th, 2006 at 10:50am
no i want to save it seperate but i think that there is missing a method to save the timetabel in the schedule.save file because when i press on the save button nothing happend and when i do the same in the demo.exe example i can see direct that the appointment is saved in the schedule.save file
