Very Hot Topic (More than 25 Replies) Disable node resizing (Read 17520 times)
Re: Disable node resizing
Reply #15 - Mar 8th, 2009 at 10:52am
Hi Hai,
This is for your "user to be able to Drag the node on first click" requirement. Set this property to AutoHandles and this should work, without you having to handle mouse event and deal with the selection.
Hai
Reply #16 - Mar 9th, 2009 at 11:14am
Hi Stoyan
I've played with it a bit… it is cool but unfortunately it does not helping me…
What I need is:
1. When the user click on the node I want him to be able to drag it. Not only when he clicks in the middle… I'm fine with mouse events, is there a way to achieve this ?
2. I must get rid of the multi-selection rectangle… Have you checked it ? As I mentioned before it appears without pressing Ctrl and I do not use Modify.
3. The AllowMultiple will be on the coming version ?
The multiple selection (And the rectangle) are very problematic since I present info for the selected node. Multi-select mess me up…
Many Thanks
Hai
Reply #17 - Mar 9th, 2009 at 2:39pm
Hi Hai,
At this time you could do that using a custom Behavior object. We'll upload a version with the AllowMultiple property tomorrow.
Hai
Reply #18 - Mar 10th, 2009 at 2:14pm
Hi Stoyan
I cannot figure out how to create the CustomBehavior and how can it solve problems 1 and 2 from my previous post.
Will you be kind to give me a code snippet or sample ?
+ Is there an estimation on when the next version be released ?
Thx
Hai
Reply #19 - Mar 10th, 2009 at 4:12pm
Hi Hai,
This version adds diagram.Selection.AllowMultipleSelection property:
https://mindfusion.eu/_beta/diaglite_allowmultsel.zip
Set it to false to disable selecting multiple items.
I'll post sample custom behavior code tomorrow.
Hai
Reply #20 - Mar 10th, 2009 at 4:42pm
Hi Stoyan
I can't find this property  ???
Checked my references
Restarted VisualStudio
Restarted my computer
Deleted and added again the reference
Can you please double-check that this property is there....
Thx
Hai
Reply #21 - Mar 11th, 2009 at 10:34am
Hi Hai,
It is a property of the Selection class. You can set it like this:
diagram.Selection.AllowMultipleSelection = false;
Reply #22 - Mar 11th, 2009 at 3:19pm
Hi Hai,
Get this version:
https://mindfusion.eu/_beta/diaglite_custbehavior.zip
Add a class that looks like this:
public class MoveNodesBehavior : BehaviorBase
	public MoveNodesBehavior(Diagram diagram) : base(diagram)
	public override InteractionState StartDraw(Point point)
		DiagramNode node = Diagram.GetNodeAt(point);
		if (node != null)
			return new InteractionState(node, Action.Modify, 8, point);
		return null;
And set diagram.CustomBehavior = new MoveNodesBehavior(diagram);
Hai
Reply #23 - Mar 12th, 2009 at 12:54pm
Thank you Stoyan, It seems like it did the trick...
One selection, move with a single click.
Many thx
Hai
Hai
Reply #24 - Mar 15th, 2009 at 2:10pm
Hi Stoyan
We would like to contact you on the phone (if it is possible).
Can you please supply me with your office phone number and your working hours ?
Thank you
Hai
Reply #25 - Mar 16th, 2009 at 8:55am
Hi Hai,
You can use the phone number listed here:
http://www.mindfusion.eu/contacts.html
If you are in IL, we should have almost the same working hours. We are at GMT+02.
