Hot Topic (More than 10 Replies) Drag and Drop from JTree to Diagram Node - is this possible? (Read 10409 times)
AR
Oct 4th, 2016 at 2:26pm
Our diagram sits next to a JTree, and we would like to be able to select an item or items from the JTree and drag them onto a Diagram Node.
Note that the items in the JTree are not JDiagram items, but would need to be converted to items which the Diagram Nodes do support/contain, however we do currently have functioning code to perform this conversion.
Is this theoretically possible? Do Diagram Nodes support classic drag and drop functionality? If not, might it be possible to use the clipboard functionality to 'simulate' drag and drop functionality?
Re: Drag and Drop from JTree to Diagram Node - is this possible?
Reply #1 - Oct 4th, 2016 at 5:06pm
You can use Java standard Transferrable and TransferHandler APIs for drag and drop -
https://docs.oracle.com/javase/tutorial/uiswing/dnd/index.html
You can find these used in FormEditor, Flowcharter and Demo sample projects. JDiagram.jar also contains public DraggedNode and DraggedNodeTransferable classes used by NodeListView, to which DiagramView responds automatically by cloning the dragged node, so you could as well return these from the JTree's transfer handler.
AR
Reply #2 - Oct 5th, 2016 at 3:18pm
All your examples show 'drop' onto the DiagramView and create a new DiagramNode.
What we actually want to do is 'drop' onto an existing DiagramNode (actually a CompositeNode) to add data to it. I can't find 'addTransferHandler()' on DiagramNode, so I assume this isn't directly supported.
Is it possible to, easily, detect which DiagramNode (if any) is in the position being 'dropped' on in the DiagramView, to enable us to make it look as if the 'drop' was onto the DiagramNode itself?
Reply #3 - Oct 5th, 2016 at 5:27pm
Call the getNodeAt method -
Point mousePosition = view.getMousePosition(true);
Point2D diagPoint = view.deviceToDoc(mousePosition);
if (diagram.getNodeAt(diagPoint) instanceof CompositeNode)
AR
Reply #4 - Oct 6th, 2016 at 12:46pm
I've tried your suggestion but the call to
diagramView.getMousePosition(true)
is returning Null.
The diagramView object seems to be okay as far as I can tell. If I look on its diagram object I can see the 3 composite nodes which are on the particular diagram I am testing with.
Any idea why getMousePosition(true) might be returning null? [Have also tried getMousePosition() and getMousePosition(false) but they also return null]
We're using version 4.1.3 of JDiagram with Java 7.
Reply #5 - Oct 6th, 2016 at 4:46pm
It's supposed to return null if the mouse pointer is not directly over the view -
http://docs.oracle.com/javase/7/docs/api/java/awt/Component.html#getMousePositio...
The built-in importData used by NodeListView checks for null, so I guess Java also calls it in situations where the pointer isn't over the view and you should check for null too -
if (mousePosition == null)
    return false;
AR
Reply #6 - Oct 7th, 2016 at 8:49am
Initially I was always getting null, even when I 'dropped' on a CompositeNode but now I do get a Point value - unfortunately it doesn't seem to match the CompositeNode I am dropping over.
For example, on a very simple diagram with a single CompositeNode the drop values I get are:
Point x = 19, y = 118
which converts to
Point2D x = 9.75, y = 84.0
(after this I get a number of 'null' drop points as part of the same 'drag and drop' motion)
but the bounds of the single CompositeNode are:
x = 464.25
y = 168.0
width = 100.0
height = 100.0
From running in debug mode, and observing when I get the 'drop' value, this seems to come as the mouse moves from the JTree onto the Diagram, and when I actually 'drop' the item I get a 'null' position. Is there anything I can do about this?
« Last Edit: Oct 7th, 2016 at 10:01am by AR »
Reply #7 - Oct 7th, 2016 at 1:18pm
Are you sure you are calling getMousePosition on DiagramView instance? You can find attached modified FormEditor that either creates a new node or adds the dragged string to existing one at current mouse location -
public boolean importData(JComponent c, Transferable t)
	if (canImport(c, t.getTransferDataFlavors()))
		// Can only drop on the flow chart control
		if (!(c instanceof DiagramView))
			return false;
		if (t.isDataFlavorSupported(DataFlavor.stringFlavor))
			try
				String text = (String)t.getTransferData(DataFlavor.stringFlavor);
				DiagramView view = (DiagramView)c;
				Diagram diagram = view.getDiagram();
				DiagramNode node = diagram.getNodeAt(diagPoint);
				if (node instanceof TableNode)
					TableNode table = (TableNode)node;
					int lastRow = table.addRow();
					table.getCell(0,  lastRow).setText(text);
				else
					diagram.getFactory().createTableNode(
						diagPoint.getX(), diagPoint.getY(), 50, 80, 1, 0);
			catch (Exception e)
				e.printStackTrace();
	return false;
It doesn't seem to return null at any point, which might be related to the (c instanceof DiagramView) check.
drag_test.zip (Attachment deleted)
AR
Reply #8 - Oct 7th, 2016 at 2:48pm
I ran your example code and it worked fine - thanks for supplying that it was very helpful.
I noticed you were using :
importData( JComponent comp, Transferable transferable )
canImport( JComponent comp, DataFlavor[] transferFlavors )
whereas I was using the versions which take a single TransferSupport parameter.
I have now changed to using the same methods as your example and it is working fine Smiley
Do you have any idea why one method would work and the other not?
All I need to do now is 'refresh' the view/diagram so I can see the new item on my CompositeNode.
AR
Reply #9 - Oct 7th, 2016 at 4:25pm
Got the refresh working too now.  Smiley Smiley
Reply #10 - Oct 10th, 2016 at 6:48am
A similar single-parameter version works for me, I'm guessing that's related to your old code not checking if target is a DiagramView before converting mouse position -
@Override
public boolean importData(TransferSupport support)
	if (canImport(support))
		java.awt.Component c = support.getComponent();
		Transferable t = support.getTransferable();
			return false;
			try
				else
			catch (Exception e)
	return false;
@Override
public boolean canImport(TransferSupport support)
	DataFlavor[] flavors = support.getDataFlavors();
	for (int i = 0; i < flavors.length; i++)
		if (DataFlavor.stringFlavor.equals(flavors[i]))
			return true;
	return false;
