Normal Topic ShapeListBox png & jpg (Read 5527 times)
08804139
Nov 3rd, 2018 at 6:14pm
HI
I want to create a diagram (Web Forms asp + c#) with a list of images png or jpg, defined in the box ShapeListBox,
So I want to use a custom list of images.
I want to replace Solution 1 with Solution 2 as presented in the attachment.
Re: ShapeListBox png & jpg
Reply #1 - Nov 5th, 2018 at 9:54am
ShapeListBox can only display Shape objects with their vector path definitions, so you could create these as custom Shapes using shape designer tool and load shape library file in the list box. Otherwise use NodeListView to show the bitmaps, where you add a ShapeNode with Image and Transparent properties set for each image.
Reply #2 - Nov 6th, 2018 at 9:33pm
Thank you for giving me more details.
How do I use NodeListView in asp webforms
and how can I fill this list by shapenode Image.
Thanks. Huh
Reply #3 - Nov 7th, 2018 at 12:06pm
This is shown in the Controls sample project -
<ndiag:NodeListView runat="server" ID="nodeList" ...
var node = new MindFusion.Diagramming.ShapeNode();
node.Text = shapes[i];
node.Shape = Shape.FromId(shapes[i]);
nodeList.AddNode(node, shapes[i]);
Add a node.Image or node.ImageUrl  assignment to show images.
Reply #4 - Dec 5th, 2018 at 9:03am
I changed list shape by diagram view where I defined shpenode.
I want to fill an accordion component with shapenode.
I defined accordion :
<ui:Accordion ID="Accordion1" runat="server">
</ui:AccordionItem>
and I managed to define the accordion items
c# :
AccordionItem _accordionItem = new AccordionItem();
_accordionItem.ID = "AccordionItem" + Accordion1.Items.Count + 1;
_accordionItem.Title = _famille.Designation;
Accordion1.Items.Add(_accordionItem);
how can i define components in accordion item with c # code ?
Thanks for your help
Lyubo
MindFusion team
Reply #5 - Dec 5th, 2018 at 10:27am
One of the ways to do that is to create templates for the accordion items, that will contain the node lists with the selected shape nodes. For example:
// The template class that adds the node lists to the items
public class AccordionItemTemplate : ITemplate
  // Initialize the item with the node list to display
  public AccordionItemTemplate(NodeListView nodeList)
    this.nodeList = nodeList;
  private NodeListView nodeList;
  // ITemplate.InstantiateIn implementation to add the node list to the item's controls collection
  public void InstantiateIn(System.Web.UI.Control container)
    container.Controls.Add(this.nodeList);
// Create the node list for the item
NodeListView nodeList1 = new NodeListView();
nodeList1.ID = "nodeList1";
// Add some nodes
node.Text = "Actor";
node.Shape = Shape.FromId("Actor");
nodeList1.AddNode(node, "Actor");
node.Text = "Ellipse";
node.Shape = Shape.FromId("Ellipse");
nodeList1.AddNode(node, "Ellipse");
// Create an AccordionItem and assign it's template
var item1 = new AccordionItem();
item1.ID = "AccordionItem" + (Accordion1.Items.Count + 1).ToString();
item1.Title = "AccordionItem " + (Accordion1.Items.Count + 1).ToString();
item1.Template = new AccordionItemTemplate(nodeList1);
// Add the created item to the parent Accordion
Accordion1.Items.Add(item1);
// ... Create more items in a similar manner and add them to the parent accordion ...
// Finally, call the DataBind method on the Accordion
Accordion1.DataBind();
The result can be seen in the attached image.
Lyubo
