Normal Topic NodeListView Sample for Winforms (Read 2145 times)
Ismail
Dec 11th, 2020 at 1:55pm
I can't find a Winforms sample (C#/VB.NET) for the use of NodeListView. I am interested in using this component to drag shapes and connectors to the canvas. Is there a sample demonstrating this that I'm not aware of?
Does NodeListView allow defining different connectors?
Re: NodeListView Sample for Winforms
Reply #1 - Dec 11th, 2020 at 2:31pm
You can find NodeListView used in "Logic Model" example at https://mindfusion.eu/products/winforms/diagramming/samples but it's not showing anything else other than AddNode calls.
Unfortunately you can't add connectors to NodeListView at this time. You could however add shapes representing connectors to the list, and replace them with DiagramLink instances when dropped on canvas -
https://mindfusion.eu/blog/create-diagram-connectors-using-drag-and-drop/
The code from blog above is for WPF, but WinForms API should be mostly the same.
« Last Edit: Dec 11th, 2020 at 5:11pm by Slavcho »
Ismail
Reply #2 - Dec 12th, 2020 at 2:23am
Thanks for the fast response Slavcho.
Ismail
