Normal Topic When DiagramNode is selected, the vertical scroll bar of UserControl moves (Read 844 times)
koichi_satoh
Mar 4th, 2024 at 11:08am
Two UserControls are stacked to display a vertical scroll bar.
I have a DiagramView placed in the inner UserControl, but when I select a DiagramNode in the DiagramView, a problem occurs where the vertical scroll bar moves automatically.
Is there a lack of focus control?
If anyone has had the same problem and resolved the issue, I would like to get some advice.
Re: When DiagramNode is selected, the vertical scroll bar of UserControl moves
Reply #1 - Mar 4th, 2024 at 11:43am
DiagramView focuses itself when clicked, and outer scrollable panels might decide to scroll to show newly focused inner control. Check if answers here help -
https://stackoverflow.com/questions/419774/how-can-you-stop-a-winforms-panel-fro...
koichi_satoh
Reply #2 - Mar 8th, 2024 at 6:03am
Thanks to you I solved it.
thank you very much.
